TwinTurbo.NET: Nissan 300ZX forum - Re: They bolt the transmission bellhousing to the motor!
boostlv
on December 28, 2012 at 5:11 PM
posted by JonnyZ(SoCal)
on December 27, 2012 at 08:07 PM
Hey what a cool guy!! thanks JonnyZ your a cool guy man, wish I met u before. By the way I'm still leaking oil guys!! not as bad though
Transmission bolts
boostlv
15:59:17 12/26/12
That bolt is either the wrong bolt, or its not tight.
Summeronthechain (MN)
16:32:12 12/26/12
Wow I'm so pissed right now
boostlv
17:48:50 12/26/12
Replacing the clutch aon 20yo car is not a BS problem
19:24:09 12/26/12
uh...wow
aliaZ
17:38:14 12/26/12
I contacted the mechanic
boostlv
17:43:31 12/26/12
I managed to tighten
boostlv
19:23:46 12/26/12
Did you get the ground for the starter harness arounditfirst (n/m)
19:25:23 12/26/12
Re: Did you get the ground for the starter harness arounditfirst
boostlv
20:22:46 12/26/12
That thick bundle of cable with the heat shield around it
Broke_as_****
22:56:57 12/26/12
I dont think it uses that bolt.
Woody75 (Denver)
09:55:15 12/27/12
Woody75 You're right it's the bolt
boostlv
10:22:26 12/27/12
boostlv
20:00:16 12/26/12
Does it go on the bolt??
boostlv
20:24:31 12/26/12
It is obvious you did not take your car to a knowledgable
Xteam300TT (South Tx )
23:21:13 12/26/12
Well the mechanic took a long ass
boostlv
10:28:39 12/27/12
oww yea 1 more thing
boostlv
10:33:24 12/27/12
Wait .... As AliaZ already said , those bolts do not block
16:16:09 12/27/12
Ok maybe I'm tripping
boostlv
17:45:45 12/27/12
What do the bolts do???
boostlv
17:49:52 12/27/12
JonnyZ(SoCal)
20:07:10 12/27/12
^^ True this ^^ (n/m)
22:17:12 12/27/12
Re: They bolt the transmission bellhousing to the motor! -
boostlv
17:11:41 12/28/12
Believe it or not I'm leaking
boostlv
17:58:40 12/27/12
